Message 11 of 30
Re: TV reception!
Also worth checking your local transmitter status:
https://www.bbc.co.uk/reception/check-for-transmitter-faults/#/undefined
Message 12 of 30
Re: TV reception!
Also, depending where you are in the country, it's possible that high atmospheric pressure is the issue.
https://www.freeview.co.uk/help/service-updates/high-pressure-could-affect-reception-Southern-Englan...
Message 13 of 30
Re: TV reception!
@BarryT33
Before you order an attenuator have you actually checked the signal strength on the main TV channels?
You're looking for 100% quality and strength in the range of ,say, 80-93.
Message 14 of 30
Re: TV reception!
I am getting the same issue. Perfect picture on TV but only 48% signal strength on BT TV. Odd as the TV is connected through the BT TV box. Will try an attenuator.
Message 15 of 30
Re: TV reception!
@Devonboy
An attenuator would not help in your case, its only any help if the signal level is showing 95% or above, and usually 100% (it cannot display an overload status).
TVs are designed to work over a very large signal range, and they can also tolerate higher error rates as most do not have to record the data stream.
Message 16 of 30
Re: TV reception!
Thanks Keith, does that indicate a fault with the BT TV box?
Message 17 of 30
Re: TV reception!
Not really, you probably do not have a strong enough signal from your aerial.
Message 18 of 30
Re: TV reception!
@Devonboy
What level of strength & quality does your TV show?
It may seem odd but if your signal strength is very high it can actually overload the tuners and they then show a low strength figure. This isn't too likely in your case  but getting the TV's figures could clear this up.
Message 19 of 30
Re: TV reception!
Guys.
I found the way to check signal strength, 63ish /100 ish (Ch 12 not 114) but alas, having already re-tuned and lost signals, can only get low quality, (not HD) so I'm rather hoping that the "high pressure" goes away and when I next re-tune they (HD channels) come back!!   I guess something may have happened to my account and my HD being turned off??        So I may check on that (only just thought that MAY be a reason...)
I took up (HD) with BT::      What's the deal with having to pay "extra" for HD reception?  When were NON HD TV's last made, quite some time back, I'm assuming.
I still never get a CHAT button on my BT homepage??
Message 20 of 30
Re: TV reception!
Sky and Virgin charge extra for HD but this shouldn't affect terrestrial channels on BT as they're broadcast via Freeview.
