higgivj99
Message 1 of 3
TV signal weak or lost
Hi
Can anybody tell me why I keep getting a 'weak/lost tv signal' error message whilst watching tv on most of the channels (including terrestrial). I have checked all cables & rebooted the BT box but to no avail.
Thanks in advance.
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: TV signal weak or lost
Hi @higgivj99,
If you take a look at Channel problems on BT TV, you'll find a few suggestions on how to improve the picture quality.
Please give that ago and let me know how you get on?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
V_Meldrew
Expert
Message 3 of 3
What region are you in? the main tower at Emley Moor (Yorkshire TV) has been switched off for building maintenance work and all channels are coming from a temporary structure probably at reduced power
