Moderator
Moderator
Message 11 of 29
Re: TV signal weak or lost
Hi @zzzzak ,
Thanks for the post. Sorry for the delay in getting back. It sounds like things have improved at your side. Give it another few days and post back to let us know how you're getting on.
Cheers
David
Message 12 of 29
i got a stonger signal  but i am still losing channels  and i got a tv booster tv aeral and the  signal stength this 100/perect and i still lost  channels like usa+1 freesport now 80  . i got a commune aerial i share with 5 off my neighbours in my flat the cancel will not let me have a out door aeria so i dont know what to do to get the channels i lost ?
Message 13 of 29
So far so good. It's been several days since we've lost our tv service - hopefully the 59 filter has done the trick.
I will continue to monitor the situation and will get back in touch if necessary, but in the meantime; thanks for all your help and support over this matter.
Recognised Expert
Message 14 of 29
@ken2222
Sometimes having a high signal strength can be the problem as it was for the OP.
You mention a booster , well that might be boosting too much so for starters try to remove that from the feed to the Yoview box.
Message 15 of 29
Hi, sounds like the same issue as me. Where did you install the filter? Coax-box or aerial-coax?
Message 16 of 29
I've tried fitting a 59 filter and I've tried reducing the signal strength to about 85% using a variable attenuator, as suggested, but I'm still getting the same problem. Since BT sent me a new Youview box I keep losing service and have to reboot the topbox. This is happening every few days and is increasingly irritating. The loss of connection also means that the system doesn't record the programmes I've set up.
Message 17 of 29
I've lost my TV service again! That's the second time this week. Clearly the issue has not been solved by reducing my signal strength.
I've tried everything that's been suggested and I'm still getting a unsatisfactory service. I feel that it's the new Youview box that's at fault.
Moderator
Moderator
Message 18 of 29
Hi @zzzzak welcome and thanks for the update. Sorry to hear things didn't stay working for long. I've sent you a Private message explaining how you can contact the forum moderation team so we can look into this further for you.
Check here: https://community.bt.com/t5/notes/privatenotespage
Cheers
John
Message 19 of 29
Thanks @NeilO for your support with this issue.
My tv has been fine for the last couple of weeks but tonight when I switched on, it had lost service -- there was just the message saying that the signal was weak or lost.
I re-booted the Youview box and everything re-connected.
I've tried everything that's been suggested but nothing seems to have solved the problem.
Message 20 of 29
Still having problems . . .
I keep losing my TV service every few days. This has been going on for several months and is increasingly aggravating.
@NeilOdid think it was a problem with my Youview box.
