Moderator
Moderator
Message 21 of 29
Re: TV signal weak or lost
Hi @zzzzak I'm sorry for the delay replying I've not been in the office recently.  I've arranged for a replacement box to be sent and it will arrive in the next day or two.
Message 22 of 29
Thanks for that @NeilO
Newbie
Message 23 of 29
I had an issue where I could no longer receive terrestrial channels and even had a BT engineer visit twice. Installing an attenuator and reducing the signal strength was the holy grail which fixed the problem permanently. Previously my signal strength was 100% and lowering it made the box work reliably.
Thanks for the help on resolving my issue. Maybe BT should be trained to recognise this issue themselves so that end users dont have to resort to trawling the internet for fixes ?
Recognised Expert
Message 24 of 29
Unless she is close to the transmitter then an indoor aerial is a waste of time. If she lives in a Freeview Light area then her only choice is a satellite dish. You can check which channels are available where she lives by using the postcode checker here:
https://www.freeview.co.uk/
Message 25 of 29
We are having the same issue having only switched to BT TV from Sky on Friday - how do you do a maintenance mode full reset as we don't have any recordings as of yet just a box that cuts out every 3-4 seconds!
Recognised Expert
Message 26 of 29
Could you be a little clearer of the issue you are having, picture, sound, terrestrial or Now TV channels?
Message 27 of 29
The picture piccolates as the signal fluctuates between 70-80 and then 0 for both quality and strength. This affects the sound too and is across all channels. I know it has been windy the last few days but it is quite today and the same thing is happening today but not quite as severly.
Recognised Expert
Message 28 of 29
You say all channels. Does that include the BT subscription channels?
Message 29 of 29
They are not as bad as the Freeview channels granted but I think it is a combination of the aerial and also the cable too but we have an engineer now booked in a couple of weeks so hopefully it can get resolved but thank you for replying.
