vegasgo
Message 1 of 6
Talktalk boosts appearing on BT Youview box?
Hi, finally got connect to broadband today, having opted for the TV Entertainment pack with BT Sport via a youview box. I cannot find the channel anywhere in the guide for the BT Sport channels, but I can get them online. However all Sky Sports channels are showing when I thought you could only get 1 & 2. When I tried to subscribe to them through youview, it’s asking for my Talktalk password? I just don’t get it? I also paid £3 extra for the kids channels, but again it’s asking me to subscribe with Talktalk for £5??? Maybe my paid-for channels aren’t activated yet, but really puzzled over Talktalk showing up on BT. Thanks for listening.
5 REPLIES 5
Distinguished Guru
Distinguished Guru
Message 2 of 6
Re: Talktalk boosts appearing on BT Youview box?
welcome to the forum @vegasgo
Couple of questions -  are you using the Youview box that Bt supplied ?
Was Talktalk your previous broadband prtovider ?
Also did you connect up  the the Youview box before your BT broadband  was activated ?
vegasgo
Message 3 of 6
OK, food for thought here. I requested my existing phone number to be transferred to our new home from Virgin. This hasn't happened yet, I've got the previous owner's number, who had talktalk. I guess I have his talktalk TV setup as well. I am using a youview box BT supplied - broadband was activated first though. Been told my number won't change until the 29th Feb - will i then get my BT TV?
vegasgo
Message 4 of 6
Just realised my activation date has been put back until the 29th (grr) - guess I'm using the old talktalk account that hasn't been disconnected yet.
Distinguished Guru
Distinguished Guru
Message 5 of 6
The indications are that the Youview box (its IP address and/or the ISP configuration) are being interpreted by Youview as being on a TalkTalk connection and Youview has loaded the TalkTalk player and a range of channels that are available (albeit) with subscription on the TalkTalk service.
If you have a look at
Youview > Settings > System Information > Software Versions
what is the ISP configuration set to ?
It could be worth doing a software update
Youview > Settings > Device Management > Software Update
If the software update attempt has no effect it may be worth trying again tomorrow again.
vegasgo
Message 6 of 6
I tried to redo the software but it said I already have the up to date version.
I do think my broadband/tv is running off the non-as-yet disconnected talktalk service, so I hope this will remain active until BT finally officially connect me.
Thanks for all your help Guru.
