Swans123
Message 1 of 22
Tv aerial
I am due to have BT tv and internet installed and I am wondering wether I need an aerial connection for it to work?
21 REPLIES 21
Zombie
Expert
Message 2 of 22
Re: Tv aerial
Yes you will need an aerial for the free view channels like bbc and itv, but the subscription channels will be delivered over the internet.
Swans123
Message 3 of 22
Re: Tv aerial
Is there any way around this?
Message 4 of 22
Re: Tv aerial
not if you want freeview channels
Swans123
Message 5 of 22
Re: Tv aerial
Best get the drill and coax cable out then. Thanks for the reply’s.
sea2dog
Message 6 of 22
Re: Tv aerial
Do you receive the freeview channels in HD using an aerial when you have the TV Max HD?
-Richie-
Expert
Message 7 of 22
Re: Tv aerial
Yes, all freeview channels including HD freeview channels are delivered via the aerial, regardless of what BTTV package you have.
sea2dog
Message 8 of 22
Re: Tv aerial
Thanks, are the pictures good as in as good as through cable?
I only ask as whenever I think of aerials I think of the dodgy pictures we used to receive prior to cable broadband.
-Richie-
Expert
Message 9 of 22
Re: Tv aerial
That would depend on the quality of the aerial and the wires connecting, I've had Sky, Virgin and BTTV over the years, picture quality was unnoticeable between them.
sea2dog
Message 10 of 22
Re: Tv aerial
Thanks Richie.
Would you think that if the aerial was placed in the loft rather than the roof that it may hinder performance?
