Davey22
Newbie
Message 1 of 3
Tv volume in PVR mode
I have a BT youview box t2100 and i am trying to program the remote  to control the volume on my LG tv, rather than using the youview box volume.
I have got the remote programmed to control the volume but it only works when i have first pressed the TV button on the top of the remote , if i am in PVR mode it just controls the volume of the youview box.
How can i control the TV volume while in PVR mode?
It is very annoying to have to press the TV button first, then remember to go back into PVR mode to change channels.
2 REPLIES 2
gomezz
Recognised Expert
Message 2 of 3
Re: Tv volume in PVR mode
That is the way the supplied remote works. One option is to treat yourself to a universal remote such as the Logitech Harmony 650 which will let you do what you want.
TimCurtis
Recognised Expert
Message 3 of 3
It seems like you've got one of the early controllers that came with the DTR-T1000 boxes, current ones don't have that multi-device functionality. There's pluses & minuses to that.
