Message 1 of 6
Two Remote Controls
Coming from Sky Q we was able to have two remote controls, onw for the wife and one for me. Is it possible to have two remotes on bt tv pro box ?
5 REPLIES 5
Message 2 of 6
Re: Two Remote Controls
The supplied remote is bluetooth so I'd be surprised if two could be paired simultaneously. But the Pro Box also has an IR receiver that responds to previous generation remotes using the Humax code set. So one of these or similar should work as a secondary remote.
** I'm no longer active on the forums. **
Message 3 of 6
Where is the infared receiver on the box? As we have it hidden it doesn’t pick it up but I have an infared extender but this needs to be in sight of where the infared point on the box is.
Message 4 of 6
Roughly half way between the centre "BT" button & the right hand edge. Around the Status LED.
Message 5 of 6
@rbz5416
Essentially as long as the older remote control (for Z4, G4 and G5) has 'line of sight' with the F1 Pro Box, it should work.
Message 6 of 6
@PhilipL790wrote:
@rbz5416
No idea what relevance that has to the question I was answering?
