liamstears
Message 1 of 8
UHD Box dies overnight
Got a strange issue with my UHD box
Sometimes after the box has been left a while (overnight till next evening) it will not turn on, many times there is even no lights on the front and it wont turn on, I have to turn off at the switch at the back and turn back on to get the box to wake back up
Has anyone else experienced this issue?
I thought maybe it was a faulty box and replaced it with a brand new v3 box but it too has now had the same problem, dead after being left and no lights, power cycle using rear switch fixes it
I am using a denon avr-x2200w amplifer and Sony KD55X8509C TV
I know my TV has the juddering issue with 4K (currently have the box in 1080p mode for this reason), could the tv also be causing this issue maybe?
Hope someone has had this same problem and has some insight
7 REPLIES 7
Distinguished Guru
Distinguished Guru
Message 2 of 8
Re: UHD Box dies overnight
Can you clarify a few things.
You have experienced the problem with two different boxes --not clear on the v3 reference you use  for the second box... was the second box also a Ultra HD box supplied by BT or a different sourced  or type of box ?
Did you use the same or a second power supply unit with the second box ?
Which Home hub are you using ?
Is the Youview box connected by ethernet cable to the Home Hub ?
Precisely how regular is the problem ?
watttwo
Message 3 of 8
very strange i have the same set up denon amp and a new 4k sony
bt came out and replaced my ultra box 2 weeks ago and now the same fault has started again
no lights on box
the amp is on in the morning whick looks like the bt box is coming on overnight
only appears to happen went the boc has not been used for a couple of days
connected via ethernet to smarthub
used new power supply that came with new box
liamstears
Message 4 of 8
Regarding the V3 there is the model number on a white sticker on the bottom of the box which ends in V2 or V3, both are BT 4K Ultra HD boxes
Different box different power supply
Not using a home hub, with talktalk and using a talktalk router (have no internet issues, all internet tv works fine)
Ethernet cable yes
Regular, unsure, once every week maybe, sometimes more frequent and sometimes less
TV has been updated now to fix the juddering 4k problem so hope this will fix this problem too but not hopeful...
liamstears
Message 5 of 8
no lights on box
What tv do you have?
Distinguished Guru
Distinguished Guru
Message 6 of 8
Are you missing any recordings due to the box not coming out of its apparent dead state or do your scheduled recordings still occur when the box is left in standby ?
srpsrp
Expert
Message 7 of 8
probably related to the smart standby feature, which i have alread reported breaks the HDMI setting. Try turning that off, the box only uses 15W so the savings are minimal any way.
watttwo
Message 8 of 8
thanks
will try this tonight hopefully this will work
