Message 1 of 3
UHD Box keeps going into Maintenance Mode
Any reason why box on booting up goes straight to blue screen mainteance mode?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: UHD Box keeps going into Maintenance Mode
@Archie1971 That shouldn't be happening, I'd recommend you report the issue to the BT TV helpdesk for further investigation.
BT TV Expert
Message 3 of 3
@Archie1971 Heya,
I am a BT employee and will investigate your issue. Are you able to PM me your telephone number so I can investigate further.
Sounds like a hardware failure on the set top box.
Look forward to hearing from you.
