Friendy02
Newbie
Message 1 of 2
Unable to record
Whenever I try and record any programme it comes up with error ‘this programme can’t be recorded. Please try again later’ this isn’t the first time it’s happened, got a new box sent out and now 2-3 months later the same thing has happened again
1 REPLY 1
Distinguished Guru
Distinguished Guru
Message 2 of 2
Re: Unable to record
Well assuming you can watch the channels live , and are maintaining aerial and internet connection to the Youview box then I would suggest when not recording that you try a soft reset of the Youview box by pressing the power button for 8 seconds to see if that clears the problem upon restarting.
A maintenance mode reset  2 or 4  would be the next step.
