Message 1 of 3
Unable to see Freeview channels (1-306).
Everything has worked well for a year then just no signal,  The aerial is still carrying a good signal, (tested with another TV.  I have BT TV package chn 307 and above work fine.
Any sugestion would be appreciated, thanks
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Unable to see Freeview channels (1-306).
So have the channels disappeared from your Youview guide or are they there in the guide and give a no signal or other error if you select them ?
Message 3 of 3
Hi, Both, not in guide or on TV set . Error message “ no channel”. I have used the TVs built in free view receiver with the aerial and works fine but a chew to have 2 remotes and no ability to record free view channel, thanks for responding, Alan
