Everything has worked well for a year then just no signal, The aerial is still carrying a good signal, (tested with another TV. I have BT TV package chn 307 and above work fine.
Any sugestion would be appreciated, thanks
So have the channels disappeared from your Youview guide or are they there in the guide and give a no signal or other error if you select them ?
