bobrey
Message 1 of 2
Using BT Remote to control Samsung TU7100 KXXU Smart TV
Just bought replacement TV.  Have tried to programme remote using procedure & code provided by BT for Samsung ( 4483) but it does not work. Is there another code for newer models of TV? The code did work on my previous/older  Samsung Smart TV.
Any help appreciated.
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: Using BT Remote to control Samsung TU7100 KXXU Smart TV
Courtesy of @NeilO  See https://community.bt.com/t5/Archive-Staging/You-view-remote-will-not-operate-Samsung-Tv-with-advised...
The OP reported that searching as described below resolved his problem
"That's the correct code for Samsung TV's. After entering the code you need to hold down the TV button, it can take a some time for the TV to respond as your remote will try different codes for your brand of TV (the blue light will blink briefly each time it tries a new code."
