Message 1 of 1
Using Youview box with Wifi ethernet bridge
I have been using a Buffalo WLI-TX4-AG300N four ports ethernet adapters to connect my Nintendo Wii, apple tv and Sony Bravia Tv and sky HD box for years now
I read that you need to get powerline extenders for BT but they only have one port
I can confirm my 300 mbps buffalo works fine with BT TV and also with Netflix 4K using my Sony TV client
Probably range extenders are required because the average home network is quite slow but you only really need 25 mbps for 4K and for BT TV HD seems like it only uses 3-4 mbps, my adapter shows 240 mbps connection and I found it more reliable than connecting the Apple TV or the Sony TV direct that instead get much slower speeds with their single antennas
