Message 1 of 7
Voice over film on ITV Hub
I don’t know if anyone can help, but I’ll ask any way. I was going to watch a film on the ITV Hub this afternoon. When I switched it on I noticed there is a voice over the film explaining what is happening: eg: “Bill looks at the truck and back at Melissa”, whilst the film is playing. Can anyone help please, I have never come across this before?
6 REPLIES 6
Recognised Expert
Message 2 of 7
Re: Voice over film on ITV Hub
On the handset there is a button for audio description, you probably have turned this on, you need to turn it off ( bottom left on my BTTV remote )
Distinguished Guru
Distinguished Guru
Message 3 of 7
Hi @chris2400  Looks like you have Audio Description  turned on - There is an AD  button on the Youview remote that might disable this feature .
Otherwise look for a setting within the ITV Hub player to dswitch Audio Description off.
Message 4 of 7
Thank you so much, such a simple thing to do without knowing. It was really weird.
Message 5 of 7
All sorted thank you.
Moderator
Moderator
Message 6 of 7
@chris2400  Great to see all is sorted now.
Kudos for @iniltous
Cheers,
Robbie
Recognised Expert
Message 7 of 7
Blame the cat!
