victormildrew
Message 1 of 14
Volume
Hi.
I have just been connected, the sound on my youview box is very quiet i need to have the volume on 25 for comfortable hearing, is this normal for this box, when switching back to tv i have to make sure the sound is lowered.
 thaks
VictorMildrew.
13 REPLIES 13
Telecom89
Recognised Expert
Message 2 of 14
Re: Volume
@victormildrew wrote:
Hi.
 thaks
VictorMildrew.
The volume on my YV box goes from 0 to 100. I normally have mine set to 55.
It also depends what the volume of your TV is also set to.
Have you set the YouView remote to control your TV volume?
If so see: https://community.bt.com/t5/YouView-Boxes/Low-volume-on-tv-after-i-synced-remote-with-TV-Humax-NOT-T...
victormildrew
Message 3 of 14
Re: Volume
Hi Telecom89.
Yes i have coded remote to tv, I have a sat box as well, thats why I need to make sure the volume level is down before switching over to the sat box.
Thanks.
VictorMildrew.
Distinguished Guru
Message 4 of 14
Re: Volume
I generally have the YouView box set at volume 80 to 100, and that seems to match other sources.
skappy70
Recognised Expert
Message 5 of 14
Re: Volume
Can you change the volume on the G4, I have the remote synced to my TV?
TimCurtis
Recognised Expert
Message 6 of 14
Re: Volume
Certainly can.
Just hold down the AD button at the bottom left on the remote & use the volume buttons.
skappy70
Recognised Expert
Message 7 of 14
Re: Volume
Doesn't work for me, I get a muted volume symbol with disabled on screen when I try?
TimCurtis
Recognised Expert
Message 8 of 14
Re: Volume
That's strange as I did test my G4 immediately prior to posting my answer.
skappy70
Recognised Expert
Message 9 of 14
Re: Volume
And it is detailed in the User Guide. I will try a reset of the remote to see if that makes it work.
Cameron
Message 10 of 14
Re: Volume
@TimCurtis wrote:
Certainly can.
I recently had my Youview box replaced and had the same problem with the volume. With the manual long lost, after much searching on the net, this is the solution i eventually used to fix this problem.
