Johan46
Message 1 of 3
What's on BT TV?
is there an easy way to find out what's on the BT TV channels without ploughing through the whole Youview channel listings?
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: What's on BT TV?
Yes - when you select Guide on the Youview box -- use the filter option -- then you can select or navigate to Subscribed to list the BT channels only .
There are other filter options that you might find usefu . -- the default is all channels
Johan46
Message 3 of 3
That's great. Just what I wanted. How did I miss that! Many thanks.
