Message 1 of 3
What's the difference between a HD, and UHD multicast stream?
Background: I've just changed my router (to a MikroTik) and configured it to pass multicast traffic.  All HD channels are fine, but the UHD channel looks like it's struggling with bandwidth, which it isn't (router shows continuous ~60Mb stream).
Is there something fundamentally different about the way that the HD & UHD multicast streams are delivered?
Tags (2)
2 REPLIES 2
Message 2 of 3
Re: What's the difference between a HD, and UHD multicast stream?
Anybody?
Message 3 of 3
Just bandwidth from your perspective.
  1. Is the picture pixilating?
  2. Do you get the same experience using the BT Hub?
