Expert
Message 21 of 22
Re: When did BT reduce the capacity of the YouView+ 4K box
They are quite expensive AV specific disks I wouldn't bother. If you buy one from eBay then the chances are that someone had just stuck their old 1tb laptop drive in there.
I doubt BT will give you a 1TB one but worth a try?
I've actually gone back to using my old foxsat because I don't like the silly tiles.
Expert
Message 22 of 22
@Kelvin_Hardingwrote:
My 1TB box developed a fault. The replacement has just arrived, and it's 500GB. Who do I ask for a 1TB to replace mine?
If I remember correctly, when it was noticed some time ago that the 4k box had been reduced to 500GB, the question was asked and a Mod replied that in the event of a future failure boxes would be replaced like for like. I thought it was odd at the time because they can't carry an infinite stock of 1TB boxes.
Based on that thread @Kelvin_Harding you should have been sent a 1TB replacement.
