pp1
Newbie
Message 1 of 2
Why have the ethernet lights on thepowerline adaptors started flashing constantly?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Why have the ethernet lights on thepowerline adaptors started flashing constantly?
Hi @pp1,
How to check Powerline Adapters or BT Mini Connectors are working:
When your Powerline Adapters are connected to your BT TV box the Ethernet light should light up. When you're using the service the Ethernet light will flash. You may notice that the Status or Data Light on one or both Powerline Adapters changes to red or orange. This isn't something to worry about if your BT TV service is working OK.
Do you have any issues with your connection or is everything working ok?
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
