Moderator
Moderator
Message 11 of 16
Re: Wi-fi Connected Youview ever?
Hi @sja681 Sorry you were not able to get the mini connector kit ordered when you contacted us.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
sja681
Message 12 of 16
Thanks @JohnC2, have contacted you by clicking on your user name and selecting contact the mods.
malcg
Message 13 of 16
Hi just to update you all.
i received the Mini Connectors today and set them up, also ensuring Flex 600s we’re disconnected.
i have had the TV playing BT Sport 1 HD for 3 hours now without an IPC message. I wasn’t actually watching it so I don’t know if there were any blank spot or breakup but all appears to have improved.
I will monitor for the next couple of days and update all.
It does appear these new Powerline adapters do resolve my issue but watch this space,
Regards
Malcolm
sja681
Message 14 of 16
Thanks Mods,
After the snow, Parcelforce delivered the mini connectors which are installed and working. No more "we cannot detect your broadband connection / broadband connection restored" !!
malcg
Message 15 of 16
Just a quick update.
I got a second pair of adapters so I could replace my Flex 600 adapter and now all is working well.
So far no issues at all and my speed is slowly going back up after it dropped with the old powerline adapters.
No issue now with BTTV.
Regards
Malcolm
skind56
Message 16 of 16
Hi
Would I be able to order a set of Mini powerline adaptors to improve the Youview performance when using BT Sport?
Steve
