Newbie
Message 1 of 14
YMV302 Error Message - Signal is Fine
Hi, I’ve recently got a BT box but I’m having trouble with the above error message appearing every few seconds. I wouldn’t mind, but the signal is fine! No pixelating or anything. I cannot find any option to turn off the error message. Please help!
13 REPLIES 13
Message 2 of 14
Re: YMV302 Error Message - Signal is Fine
Welcome to this user forum.
First try restarting the BT YouView box, as that can help.
What signal level and signal quality is the box showing?
Newbie
Message 3 of 14
I’ve tried resetting and retuning. The signal is showing anywhere between 88-90%.
Message 4 of 14
What is the signal quality showing, as that is more important?
Newbie
Message 5 of 14
Signal quality is not good, between 15-21%. But the picture quality is perfect!
Recognised Expert
Message 6 of 14
So you've got about 90% signal strength which is maybe a little low as 95% would be better.
And about 20% signal quality which is terrible.
Have you tuned into the correct transmitter/region?
Do you know how far you're from the main transmitter? If you're very close it could be that the signal is too strong and you need to do something about weakening it, as the Youview's tuner can't well handle really strong signals.
Newbie
Message 7 of 14
I had 3 regions to choose from and with the other 2 I got barely any channels. I don’t get very good signal in my area so I have to have a booster. So I bought an attenuator as the signal was even worse without it!
Message 8 of 14
You could try adjusting the attenuator to drop the signal level slightly, to see if it improves the quality. It may not help, as I think you have a poor quality signal entering the booster.
The problem is that signal boosters do not normally improve the quality, as they introduce a small amount of noise.
It may be that you need to improve your outside aerial to get a better signal from the transmitter. A good aerial company should be able to do this properly, as they have signal level meters.
Newbie
Message 9 of 14
Okay thanks for your help, is there anyway to simply turn the message off in the mean time?
Message 10 of 14
You may be able to get rid of it by slightly adjusting the signal level on the attenuator, or there may be a gain adjustment on the booster itself.
