st3
Message 1 of 11
You View Box - Channels 101 -106 (BBC1,2 etc. HD Missing
Over this week my HD BBC1, 2 etc. channels have gone missing from my You View Box. All my subscription HD BT Sport, Sky Sport are OK and the Olympic channels have been retuned and available. Whats happened to them I have reset the box, checked to make sure signal strength is OK, retuned the channels multiple times, checked they are not hidden and also switched to my standard TV and they are all available there off the same aerial input etc. but 101-106 are still missing. Any ideas ?
Thanks Steve
10 REPLIES 10
rarmitage124
Recognised Expert
Message 2 of 11
Re: You View Box - Channels 101 -106 (BBC1,2 etc. HD Missing
Do you get any error messages when trying to access the channels?
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
st3
Message 3 of 11
No....They are just not there and when you request them it says "no channel". Thanks for replying. Steve
rarmitage124
Recognised Expert
Message 4 of 11
What sort of signal strength are you receiving with the channels that are working?
st3
Message 5 of 11
For information. I have just cracked it. My RF output was set to off. I reset to on and then retuned. 101-106 now back and working. Just if anyone else has the problem. My guess is that a box rest defaults back to off.
Message 6 of 11
RF loopthrough has nothing to do with the ability to receive channel
Sometimes the Youview retune misses out channels and then randomly you get them back
st3
Message 7 of 11
Ah well.....Never mind. Whatever it was nothing seemed to make any difference until I changed that setting. Wont touch it again just in case. I will put it down to the random problems we get when playing with technology 🙂
Message 8 of 11
You can use the loopthrough to connect your tv. You will find that when the youview looses signal or pixelates youncan still use your tv set...
Ian-M
Message 9 of 11
I have had same problem since may. Just got new aerial today but same channels still missing. Any help much appreciated
Ian-M
Message 10 of 11
Still trying to get some help with same problem
