Marg0105
Message 1 of 2
You View box Problems.
We have been having random problems with our You View box for some time, missed recordings etc. Last night it just stopped working, seemed to have 'hung' itself. We restarted it, it appeared to be rebooting but still no reaction to the remote. We rebooted it again and put fresh batteries in the remote just in case. Still nothing happening! Obviously can't tell if it's recording behind the scenes.
Is there anyway of controlling the you view box without a remote?
Any suggestions for a self help remedy for the box? Or should I just ask BT for a replacement? t is an old style BT Humax one.
Thank you
1 REPLY 1
Marg0105
Message 2 of 2
Re: You View box Problems.
I've sorted it thank you
