Message 1 of 13
You view box recordings
We had to have a new you view box as the old one was not working properly. Since we had it, i can record quite happily, except certain channels are not watchable. Especially channel 4, whole series, including Humans, is pixilated and breaking up to the point ive just deleted them all, any ideas?
12 REPLIES 12
Expert
Message 2 of 13
Re: You view box recordings
  • Model of YV Box you now have ?
  • Signal Strength & Quality (see relevant readout on 'Settings') On both 'good' & 'Bad' Channels
  • Any known Transmission problems for the TV in your area?
  • Check for 4G interference.
  • Does TV itself show a good picture for Channel 4 ?
Message 3 of 13
Thank you, yes when watching channel 4, the picture is good, no known transmission problems so yes will check signal strength where will I find model details?
Message 4 of 13
Checked youview box it doesnt actually show anything other than you view? 91-00438 is that it?
Expert
Message 5 of 13
which of these 3 is it ? http://www.productsandservices.bt.com/products/tv-packages/?s_intcid=article You can also see the Model type in the relevant section of the Settings page ...
Expert
Message 6 of 13
I would also adviae you to goto the at800 website and check for 4g interference. Just because it was not a issue before don't mean its the case now as a lot of the mobile networks have been expanding there 4g networks. Some of the bands used are close to the bands the free view multiplexs and can cause interference. The at 800 website can advise if you are in a area at risk. If you are a free filter will be sent.
Message 7 of 13
Thank you, its you view plus
Message 8 of 13
Thank you, checked the at800 no problems in my area, could it be because our TV is around 7 years old?
Message 9 of 13
Just did a re tune and checked signal quality for channel 4 and its 60% is that good or bad?
Message 10 of 13
If that is the signal quality, then 60% is poor. Quality needs to be 85-100% for the YouView box to extract an error free digital signal. You need to get your aerial installation checked.
