Message 1 of 4
You view box t2110 wifi connection
Hi. Does anyone know if there is a way of connecting my current youview box to wifi without having to physically connect it to a router,will soon be moving to a house where they have virgin tv. If so can you please link the appropriate things I need. Thank you in advance 😊
3 REPLIES 3
Message 2 of 4
Re: You view box t2110 wifi connection
You cannot connect it via WiFi, but you could use Broadband Extenders.
http://www.shop.bt.com/mini-sites/connected-home/
Message 3 of 4
Thank you.
Message 4 of 4
With a broadband extender does it plug into the extender then via the Ethernet cable as I will be using it in a bedroom with the router being downstairs?
