kymbuls
Newbie
Message 1 of 7
You view box turning on
For the last few nights my you view box has turned itself on at 1.45am which also turns the tv on. I've tried all the settings and turning off/on etc. Any ideas? It's in sleep from 1am.
6 REPLIES 6
TimCurtis
Recognised Expert
Message 2 of 7
Re: You view box turning on
You could try a soft reboot when it's not recording which is holding down the power button (on the box) for about 8 seconds
Moderator
Moderator
Message 3 of 7
@kymbuls Post back and let us know if the soft reset works, if any further help is needed we'll be able to raise a case with the BT TV team to have this investigated.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
kymbuls
Newbie
Message 4 of 7
Thanks I'll try this tonight and post back
Moderator
Moderator
Message 5 of 7
Hi @kymbuls Did the reset resolve this problem for you?
Cheers
John
Community ModeratorJohnC
Kudos”
kymbuls
Newbie
Message 6 of 7
Hi. The first night I didn't get woken up. Last night I was awake and went down to check at 1.45 and it wasn't on so all seems good. Thanks for the help guys
Moderator
Moderator
Message 7 of 7
Hi @kymbuls Thanks for posting back and glad to hear the reset fixed things Smiley Happy
cheers
John
Kudos”
