Message 1 of 2
You view recordings
I am experiencing duplicate recordings on Sony movies channel 32. Recording two lots on same channel at same time
1 REPLY 1
Distinguished Guru
Distinguished Guru
Message 2 of 2
Re: You view recordings
Hi @wye-aye-man
I believe what you are experiencing is that you are recording the same programme on two different channels at the same time. Sony Movies have been simulcasting their movies since about April 15 on both channels 32 and 792.
This is occurring because Sony Movies are supplying metadata that identifies the content on both channels as being segments of the program (the film)  that you have selected to record.  They should not be using the same data for two channels but they are. They are also persisting in the simulcast for a lengthy period.
