downlands
Message 1 of 4
You view remote will not operate Samsung Tv with advised code
The Tv is a Samsung Ue 32 j 5110  the code quoted in the user guide is 4483 but this will not work! BT support has advised me it is not possible to control this Tv ! Has anybody found a workaround or another code ?
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: You view remote will not operate Samsung Tv with advised code
@downlands That's the correct code for Samsung TV's. After entering the code you need to hold down the TV button, it can take a some time for the TV to respond as your remote will try different codes for your brand of TV (the blue light will blink briefly each time it tries a new code.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
downlands
Message 3 of 4
Thank you for your information, it was not made clear that you need to hold TV button down to enable search of codes. This did work and the handset is now programmed to the Tv , when it had finished its search the blue light on the handset stayed on! Pulled one of the batteries then retried and all was good. Please advise customer services in India that it does work and to advise there customers of the correct information!!. Thank you for your assistance.
Moderator
Moderator
Message 4 of 4
@downlands Brilliant thanks for letting me know that worked.  I'll pass on the feedback.
Kudos”Kudos”
