NiallOg
Message 1 of 5
YouView Box won't update -it's been at 0% for over 3 hours
Hi there
I selected the 'update' option for my YouView box and apart from a nice blue screen informing me that the update has made 0% progress nothing has happened. Switching off the Box does nothing as it returns to the same state so currently, the box is unusable.
It would be best if I could get the update done in a sensible timeframe, otherwise forgo the update and get the box back working again.
The box has a working Ethernet connection.
gomezz
Recognised Expert
Message 2 of 5
Re: YouView Box won't update -it's been at 0% for over 3 hours
Have you tried rebooting it by pressing and holding the power / standby button on the box?
Distinguished Guru
Distinguished Guru
Message 3 of 5
Perhaps see if after powering off if you remove the Ethernet cable and see if the box starts when the box is then powered back on. Ie will the box start without an internet connection
More details of box type .. and if you know what software version the box was on before.
Also what prompted you you do a manual update .. were you having problems  before ?
NiallOg
Message 4 of 5
it worked -thanks.
I did the update as there was a whole screen option to do so.
Moderator
Moderator
Message 5 of 5
Hi @NiallOg,
Thank you for posting back and confirming that work for you Smiley Happy
Cheers
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
