Message 1 of 3
YouView Box
Hi
My YouView box keeps freezing - screen goes black and doesn't play Freeview, subscription channels or apps. Only fix is to switch off/on at the back.
Model no. DTRT4000
2 REPLIES 2
Expert
Message 2 of 3
Re: YouView Box
It's probably over heating and locking up. Check to make sure it has good ventilation... If it has and is still doing it, call BT and they'll send you a replacement providing you have an active BT TV subscription
Message 3 of 3
Re: YouView Box
Ok will try that thanks
