chapi72
Message 1 of 9
YouView Can't delete recording program is no longer being broadcast
Hi,
I have an issue trying to delete a recording from Youview.
The box thinks that the program is still being broadcast even though they finished a day or 2 ago!
If I select them to delete I just see Deleting and the dots "...." moving, but nothing happens.
Can I get rid of them without a Factory reset?
I tried a software reset, but they were remembered as "recording".
The picture below was taken at 7am, neither program was being recorded!
8 REPLIES 8
TimCurtis
Recognised Expert
Message 2 of 9
Re: YouView Can't delete recording program is no longer being broadcast
I think a Maintenance Mode reset might do the trick. There's a guide to it here , I'd try options 2 & 4 in that order. Recordings are kept in tack with these options.
chapi72
Message 3 of 9
I'll give that a try. Thanks
srpsrp
Expert
Message 4 of 9
What happens if you try to start another recording for real then?
chapi72
Message 5 of 9
It was randomly recording some scheduled programs, failing some and there is a random amount that won't delete. Trying the factory reset tonight.
chapi72
Message 6 of 9
Hi, factory reset with keep recordings didn't help.
Still have recordings that won't delete or think they are still recording.
Ideally don't want to have to do a factory reset and delete recordings.
Any more ideas?
TimCurtis
Recognised Expert
Message 7 of 9
There has been the odd report of similar issues where maybe the internal indexes on the harddrive have become corrupted and the only solution was a complete reset wiping all recordings.
Other than that I can't think of any other option.:smileysad:
srpsrp
Expert
Message 8 of 9
could be a hardware problem then (drive ?) , get BT to send you a new box they charge enough.  it should cope with power outages so if problem is still there it probably means the disk is sat there re-mapping hundres of bad blocks.
chapi72
Message 9 of 9
Thanks, I'll try the full factory and see if the problem goes away. :smileysad:
