jaybeetoo
Message 1 of 4
YouView and HH5
Does it matter which of the yellow Ethernet ports on the HH5 I should use for the YouView box?
3 REPLIES 3
Message 2 of 4
Re: YouView and HH5
No, any of them will work just fine.
jaybeetoo
Message 3 of 4
Re: YouView and HH5
Thank you.
In that case I think one of the Ethernet ports has a fault.
skappy70
Recognised Expert
Message 4 of 4
Re: YouView and HH5
logon to the Hub and check the Port status when you connect the YV box to that port.
