JohnKelly
Message 1 of 17
YouView box does not re-connect to network after loss of connectivity
My youview box does not re-connect to the network after the home hub has dropped out. The original message I put in regarding this was moved to the BT Infinity Speed/Connection Issues forum but I still think this is an issue here. Is connectivity still an issue with the youview box or am I facing a problem? I have to restart youview whenever there has been an issue. I'd like not to have to do that. It should realise (several hours after the hub has restarted) that the network is present and use it.
16 REPLIES 16
Dave123
Message 2 of 17
Re: YouView box does not re-connect to network after loss of connectivity
I've seen the same situation with the G4 when HH5 reboots/powers off. The G4 needs to be put into standby to recover the network connection.
JohnKelly
Message 3 of 17
Just the G4 - I used to have the same problem when the previous box came out but I'd noticed it on the G4 I had until I got the HH5 and infinity.
Dave123
Message 4 of 17
No experience of previous youview box.  I changed from BTvision.
walkerx
Recognised Expert
Message 5 of 17
You should be able to just go into settings and redetect the network - try this before performing a full power off
TrickyDicky
Message 6 of 17
walkerx ......... thanks for that nugget !!!
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings Star on the left-hand side of the post.
JohnKelly
Message 7 of 17
I'll give it a go. That would help a lot.
JohnKelly
Message 8 of 17
Tried successfully. Don't know why I never tried it before. It's a lot easier than rebooting the box Smiley Happy
walkerx
Recognised Expert
Message 9 of 17
Get used to doing it on a regular basis especially as the HH5 reboots at least every 30 days
barnpiece
Expert
Message 10 of 17
MY Home Hub 5 reboots every few days (mostly in the middle of the night) and the YouView box recoonects itself without having to do anything -- Maybe because it is in Standby (low Eco mode) at the time.
Richard
