Stefan_T
Message 1 of 3
YouView box only shows UKTFAD 0.07 on the bottom left corner, otherwise it's frozen.
Hello,
my YouView model DB-T2200/BT/DF only shows UKTFAD 0.07 on the bottom left corner.
It does not react to the remote at all, which has new batteries and I've done a remote reset on it.  I've tried the factory reset procedure for this YouView box and nothing happened.
When unplugging the box from power for a couple of seconds, it takes over a minute for the red light to show. After a few more minutes the light turns blue and the text UKTFAD 0.07 appears. Can't get it to do or show anything else.
Any ideas on this situation would be very appreciated.
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: YouView box only shows UKTFAD 0.07 on the bottom left corner, otherwise it's frozen.
@Stefan_T
It sounds like its faulty. If you are still in a BT TV contract, then you can get it replaced for free.
Also see this other old thread https://community.bt.com/t5/YouView-from-BT/Error-E001-INVALID-SYSTEM-ID/td-p/1528611
Stefan_T
Message 3 of 3
Thanks for your input, will contact BT to get it replaced.
