DavidCo
Expert
Message 1 of 3
YouView+ box problems
I have been having issues with updating the software etc.
The 1st needed a factory reset that had to be done via 'buttons' as the menu did not work (frozen)
As the box booted up it said 'update running' OK! maybe.
There was another update a week or so later, I think, judging the colour sequence.
Some mornings I have had to 'fight' to get the device running properly. Setting now changed to always on!
So, I went into 'settings' and spotted something odd, so I have written out most of it.
Device Info - Humax
Model - DTRT 2110
Variant - 84B08530
Serial - +77328+1622000713
Software
Update check 22 Nov 2018
Comp' Software - 3.5.74 (bd97c9)
Man' Software - 31.28.0
Platform config' - 4392
ISP config - 21153
Those software versions do not seem to match what I have seen on this forum?
Yet the box says that they are up to date (I did a manual check)
What do you think?
David
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: YouView+ box problems
Those software versions look consistent with the official Youview update status for that box model.
remember it looks like you have the BT Retail variant of the Youview box so the update cycle can differ to those provided  with the BT TV service.
https://support.youview.com/youview-box/software-updates/latest-software-versions
DavidCo
Expert
Message 3 of 3
Thank you.
This explains why my box still has issues that showed as 'fixed' on BT
My wife will have to wait for audio playback, on recordings,  to work!
David
