Showing results forΒ
Search instead forΒ
Did you mean:Β
littlefonzy
Message 1 of 5
YouView remote Samsung TV
Hi everybody πŸ˜ƒ
Quick question.
I've just set my YouView remote to turn on/off MyBusiness samsung TV.
It also can change AV inputs, which is nice.
However, when I switch AV inputs the middle 'OK' butting doesn't seem to actually 'select' the AV input.
I would like some assistance to find the right button if possible.
Thanks for your time.
Tags (2)
4 REPLIES 4
skappy70
Recognised Expert
Message 2 of 5
Re: YouView remote Samsung TV
You have to keep pressing the AV button until it scrolls to the input you require. it's a bit ropey as sometimes it selects an input you don't want.
littlefonzy
Message 3 of 5
Thanks for the reply. Yeah, I got that far, but once I've selected the input I want the input selection takes about 2 minutes to disappear rather than 'be selected' if you get me. Any help would be great πŸ‘
skappy70
Recognised Expert
Message 4 of 5
I get you, I still use my Samsung RC to clear it 😞
littlefonzy
Message 5 of 5
Fair enough. Thanks so much for the response. Also, do you know if you can control the sound of a sound bar, at the same time as the AV/Power of the TV with YouView remote?
