Reidcassie
Newbie
Message 1 of 5
YouView remote with new JVC TV (LT-42C550)
Hi all
We have just bought a new JVC TV but cannot get the YouView remote to link to the TV, we have tried all the codes we can find! Does anybody have any ideas or has tried this already? The TV is a JVC LT-42C550.
Thanks!
Cassie
4 REPLIES 4
Telecom89
Recognised Expert
Message 2 of 5
Re: YouView remote with new JVC TV (LT-42C550)
Have you tried the vessel codes? AFAIK TVs branded 'JVC' are now Vestel re-brands. The cheaper Panasonic models are also made by Vestel and people have found that the Panasonic codes don't work with them. I suspect that you may not be able to control your TV via the YouView remote but you could give the Vestel codes a try just in case.
Telecom89
Recognised Expert
Message 3 of 5
Auto-correct changed 'vestel' to vessel...
Reidcassie
Newbie
Message 4 of 5
Thanks Telecom89 - will give it a try tonight!
MikeP18
Message 5 of 5
Hi Reidcassie, have you had any luck with this yet please?  I have just been bought same model TV and am having the same problem
