Community Manager
Community Manager
Message 1 of 1
YouView
Hi all,
We’ve updated the YouView pre-registration page with new pricing and availability info, you can pre-register YouView from BT up until 18th October and doing this gives you the opportunity to place an order before those that don’t pre-register!
Check out the page here for pricing info and other useful FAQs.
If you’re an existing BT Vision customer visit this page to find out more about what’s different about YouView.
Cheers,
Stephanie
Community ModeratorStephanie
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
