Distinguished Guru
Message 31 of 33
Re: Youview 10m Ethernet Cable
Doesn't that confirm what we thought.
The supplied 10m flat cable only gives four connected wires so doesn't support Gigabit. Not a problem when plugged into a Youview box for receiving BT TV.
The G4 box isn't a Gigabit device. Not a problem for receiving BT TV. Using a different cable won't change that. I'm assuming you have the G4?
Rayar
Newbie
Message 32 of 33
You should not really use cat5 cable over 10 meters, about 15m is the max, i would suggest. For longer routes you should use cat6
TimCurtis
Recognised Expert
Message 33 of 33
@Rayar
Why post in a thread that's nearly 3 years since the last posting?
Also  Cat5 would be adequate for far more than 15metres , more like 100metres being the generally accepted maximum.
