trevorhayward
Message 1 of 7
Youview+ (2014 G4) IR Sensor Location
I have one of the new 2014 G4 (fanless) Youview+ boxes, (the ones that match the HomeHubs) which is hidden away so am trying to set up a Marmitek IR extender to work with it, but there is no visible sign of the IR sensor on the box. Anyidea where the sensor is located ??
6 REPLIES 6
BT TV Expert
BT TV Expert
Message 2 of 7
Re: Youview+ (2014 G4) IR Sensor Location
BT TV Expert
BT TV Expert
Message 3 of 7
I thought the same so took a pair of pliers to it haha
trevorhayward
Message 4 of 7
Thanks, only problem is my IR Extender unit has to be stuck directly over the sensor, I've tried a few places roughly with what I can see in your picture but with no luck, is there anyway to get the cover off without having to take pliers to rip the thing apart ?
graystreet
Message 5 of 7
Nothing quite as satisfying as the appliance of violence!! lol
BT TV Expert
BT TV Expert
Message 6 of 7
I can't suggest running it with the front removed.
If it helps, the IR measurements are 2.5cm from the right and 1cm from the top. The plastic in front is actually a very thin lens so should help focus, rather than impeed.
Steve
brookheather
Message 7 of 7
Surely you can just stick the IR extender somewhere in front of the box - you shouldn't have to place it directly over the IR sensor as it should emit enough signal if just placed on the shelf.
