bazz02
Message 1 of 9
Youview Confused
Will youview box work on Homehub2 (or do I upgrade to 3) with Infinity.
Is there any need now for new Bt Vision Boxes or am I missing something.
As confused as ever.?
8 REPLIES 8
minusdot
Recognised Expert
Message 2 of 9
Re: Youview Confused
http://community.bt.com/t5/BT-Vision/Just-ordered-YouView-from-BT/m-p/659192/highlight/true#M37320
The HH2 will work fine.
I've no idea why you've got confused about whether you need a HH3 or infinity; neither are requirements for Youview.
swedish_cook
Message 3 of 9
In fact no Homehub is needed, in order to protect my family from the nasty parts of the web on all the gadgets in the house, using free OpenDNS,  I use a non-BT router. For those with families I could not recommend this approach any more strongly.
walkerx
Recognised Expert
Message 4 of 9
I agree - don't use a HH if you can afford a decent router buy your own
minusdot
Recognised Expert
Message 5 of 9
Do you get any QoS through YouView? If so, you may have to configure your router appropriately if it's not a HH.
Guru
Message 6 of 9
As I understand it QoS is applied to BT Player on YouView, but nothing else.
swedish_cook
Message 7 of 9
Are you saying the HH is doing QOS ? Do you have any confirmation that this is the case, first I heard of it ?
masona2
Recognised Expert
Message 8 of 9
bazz02
Message 9 of 9
Oops
No bt hub no infinity no nothing BT required for Youview.
Got it will check elsewhere.
