mld73
Message 1 of 5
Youview Remote Control - how can I find what code it is set to?
Is it possible to check what code has been set on a YouView remote control? Mine works OK, but I can't remember what code I used. Now I want to set up another remote for an identical TV.
On other universal controls, you normally press some combination of buttons, and the LED flashes out the code.
4 REPLIES 4
Zombie
Expert
Message 2 of 5
Re: Youview Remote Control - how can I find what code it is set to?
mld73
Message 3 of 5
Thank you for first reply. I know how to enter a code, but my question is - can I find out what code is in the remote control now?
Zombie
Expert
Message 4 of 5
I really don’t think there is anyway to find out what tv code is already programmed into the remote.
robc
Message 5 of 5
You could always reset the remote control:
http://bt.custhelp.com/app/answers/detail/a_id/49676/~/how-to-reset-your-bt-tv-remote-control
and then program it with codes to operate your TV.
Regards
