duncansby
Message 11 of 23
Re: Youview - Retail Boxes Get January software update
you can perform a manual update by navigating to Settings > Device Management > Software Update > Get Update, and pressing OK.
PJ_Maybe
Message 12 of 23
Forcing manual update does not work for me.
It reports that my software is up-to-date even though it's dated 4th December
chrisp18
Message 13 of 23
Thanks duncansby
As I said earlier tried that but it didn't work. However, have checked again and just managed to spot the message that the download is 33% complete.
I assume that as I am in a rural area and my broadband is somewhat slow (just done a test on broadband  speed checker.co.uk that shows my download speed as 4.75 mb/s) the download is taking it's time but will get there in due course.
chrisp18
Message 14 of 23
Further to yesterday have just checked again at 08:45 and it still shows 33% completed so no further download overnight.
Bit strange as yesterday when I checked I could have sworn that it briefly jumped from 33% to 60% i.e it started at the lower figure but briefly jumped to the higher figure. This happended each time I checked so wasn't sure which figure was right.
Getting a litttle concerned as to why the update is taking so long to install as it is now 2 weeks since it was first made available according to Sean's post. Hope delay isn't due to my box being replaced in November so hence different serial number.
bobjob
Message 15 of 23
Dont worry,what you are seeing is not the new update,your new update is a staged rollout,it doesn`t look like yours is through yet,you can check your software number in settings,device managment.the new one is 950 1.2.6. 312
chrisp18
Message 16 of 23
Thought I would check again and lo and behold the update started to download, so was obviously scheduled for tonight.
Completed successfully and software details are:
Manufacturer Software: 9.5.0
Component Software: 1.2.6
Platform Configuration: 312
ISP Configuration 27
Have found the new the HDMI audio and display options so that's fine.
Managed to find the new Search Live TV option after fiddling about and think I know how it works. Would appreciate more informative instructions for future updates.
Not looked as to where to find the new Software Update notification should I need it.
Are there any other new options I should be aware of and if so how do I find them.
PJ_Maybe
Message 17 of 23
OK forced update worked tonight.
Ah the update seems to offer dolby surround over HDMI not dolby digital
I was hoping to reduce number of cables by one.
Seems I still need the digital audio link as well as hdmi lead
Mark
Message 18 of 23
Just forced an update check on my Youview STB and I'm downloading as we speak.
Looking forward to the new features 🙂
wwwebber
Message 19 of 23
incorrect. Im able to get full dd5.1 via hdmi.
PJ_Maybe
Message 20 of 23
Interesting. That was the upgrade I was expecting.
What am I doing wrong?
QED hdmi lead connected into Sony amp that has a blue light that shows multichannel decoding.  On teh hdmi I am only getting linear........ something sound
