fizzysprite
Newbie
Message 1 of 4
Youview /TV Entertainment - Aerial Required or not?
Hi,
We recently had Bt Infinity 2 set up and have just been looking at the TV options and we are thinking about going for a YouView+ Box with TV Entertainment.
Only issue is that we don't have an aerial / we are in a bizzarre blank spot for TV signal (new build houses on the edge of a Town, everyone around us has Sky)we don't want to sign up for Sky as they are pricey, I have read on a few sites that Youview+ boxes will work without an aerial? However I wanted to double check this
3 REPLIES 3
Distinguished Guru
Message 2 of 4
Re: Youview /TV Entertainment - Aerial Required or not?
You will need an aerial for most channels.
Check coverage for your area for freeview channels here:
http://www.digitaluk.co.uk/coveragechecker/
toekneem
(EASBF)
Distinguished Guru
Message 3 of 4
None of the traditional Freeview channels will work without an aerial.  You would only get the extra channels that BT provides.
Distinguished Guru
Distinguished Guru
Message 4 of 4
I strongly recommend you check directly with Youview as to what services you might have without an aerial,
http://support.youview.com/
https://community.youview.com/youview
Also see mearglens post in this thread -
https://community.bt.com/t5/YouView-Boxes/I-don-t-have-an-aerial-and-got-the-channels-through-the-yo...
