Mark_Bea
Message 1 of 3
Youview Ultra HD box
Hi
I am thinking of switching to BT for my TV, is there an issue with ordering the ultra HD box if you have got a 4K TV, thinking future proofing, am likely to upgrade TV soon, so want the appropriate box in place.
Any advise would be appreciated....
2 REPLIES 2
Mark_Bea
Message 2 of 3
Re: Youview Ultra HD box
Sorry not sure how to edit post, should read if you have not got a 4K TV!!!!
Telecom89
Recognised Expert
Message 3 of 3
Not a problem using the 4K box on a non-4K TV. Just set the box to output 1080i/p in the interim.
Although BT will only let you order it if your impacted download speed at:
https://www.dslchecker.bt.com/adsl/adslchecker.TelephoneNumberOutput
is at least 44Mbps...AFAIK.
