Pintu
Message 1 of 10
Youview+ Ultra HD with non-4k TV and HDMI 1.4 receiver
Hello,
I am about to order BT Total Entertainment with the Ultra HD box. I have an older Sony Full-HD TV which is connected to a Denon Receiver that only supports HDMI 1.4.
Obviously I won't be able to receive Ultra HD content with this, but will I be able to watch all channels (including BT Sport) with this setup and Full HD where available?
Thanks.
9 REPLIES 9
rarmitage124
Recognised Expert
Message 2 of 10
Re: Youview+ Ultra HD with non-4k TV and HDMI 1.4 receiver
Can I quickly check that your broadband speeds are good enough by asking you to go to:
https://www.btwholesale.com/includes/adsl/adsl.htm?s_cid=ws_furls_adslchecker
And to post the results, excluding any personal information.
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
Pintu
Message 3 of 10
Thats for ADSL, I am going to order Infinity 2. How is that useful?
rarmitage124
Recognised Expert
Message 4 of 10
Its not if you follow the link and put your number in it will show you infinity speeds as well
Pintu
Message 5 of 10
I can't. I don't have a phone line yet.
rarmitage124
Recognised Expert
Message 6 of 10
You can try the address as well by clicking on "Address Checker"
Pintu
Message 7 of 10
rarmitage124
Recognised Expert
Message 8 of 10
Okay so BT always take the lowest speed and that is 39.8Mbps to have BT YouviewUHD box you need a guaranteed 44Mbps so you wont be able to get a Youview UHD box however you could still get a standard Youview box and upgrade when you get a 4k TV or when your speeds increase.
Pintu
Message 9 of 10
Are you saying that I will get 39.8 download / 10 upload if I order Infinity 2? These are effectively Infinity 1 speeds for a higher price. I also got a "guaranteed speed" of 60 mbps.
I have finished the order process of Total Entertainment with UHD as someone in online chat told me that I can use the UHD box with my FHD TV.
Distinguished Guru
Distinguished Guru
Message 10 of 10
There is a setting on the Youview box - Youview>Settings>Tv Signal & quality >HDMI Display Setting
For the UHD box currently there are 5 display settings - 720p , 1080i , 1080p , UHD 50fps8 bit , UHD 50fps 10bit so you would need to set it so it is compatible with your TV.
