Message 1 of 3
Youview, Youview+, starter and entertainment +
Hello all im hoping someone can help?
A month ago I left my old flat which had a You View + box in it from my old entertainment + package.  I had it for under a year and I now own it.  I have moved to my new flat and want BT again.  If I were to order the Youview box and starter package can I swop out the Youview bx for my Youview + box.  Im not concerned about the channels I just want to be able to record.
Hpe that makes sense.
Mike
2 REPLIES 2
TimCurtis
Recognised Expert
Message 2 of 3
Re: Youview, Youview+, starter and entertainment +
Do you want any of the BT TV channels? If not then your recording YV box will work just as a Freeview box.
Message 3 of 3
Great thanks. I would just want to record with it free to air channels.
