PB54
Message 11 of 20
Re: Youview & BT Sports
Everything shows as available including
FTTC A
FTTC B
Fibre Multicast
and Copper Multicast
Distinguished Guru
Distinguished Guru
Message 12 of 20
So it  as Steve M  explained in an earlier post -
If Fibre Multicast via Infinity is available then  BT does not currently offer copper multicast as an option for its IPTV services.
BT are offering the copper multicast option for BT Sports only where the Infinity multicast option is not available.
So if you choose to take BT Infinity then the BT IPTV channels including BT sports would be available. Suprised you haven't been offeed the opportunity to move to Infinity.
nostra999
Message 13 of 20
Hey Zulu,
Sorry for jumping in on this thread but just wondering... what if the exchange is infinity enabled but the cabinet is not? Just out of interest.
Thanks!
Richard
PB54
Message 14 of 20
Right. Got it now.
Was offered infinity but don't really need it. 16 Mbps Is fine for now. Don't want to pay more for infinity at the minute. Just would have been better on the 40 LCD than my iphone or pc monitor.
Also I think I could have had it on the old bt vision box with adsl. So seems odd I can't on the YV box.
BT TV Expert
BT TV Expert
Message 15 of 20
You could buy a Chromecast 😄
PB54
Message 16 of 20
You could buy a Chromecast :smileyvery-happy:
I could do that, i suppose. Why the :smileyvery-happy:?
Router Stats
Line stateConnected
Connection time14 days, 10:36:33
Downstream15,993 Kbps
Upstream
1,152 Kbps
Guru
Message 17 of 20
Deleted - duplicated for some reason.
Guru
Message 18 of 20
"Was offered infinity but don't really need it. 16 Mbps Is fine for now. Don't want to pay more for infinity at the minute. Just would have been better on the 40 LCD than my iphone or pc monitor."
You could upgrade to Infinity and get £50 towards the extra cost.
http://www.productsandservices.bt.com/products/broadband/packages?Infinity=yes
PB54
Message 19 of 20
Thanks.
Might toy with the Chromecast idea but tbh the BT Sports wasn't for me. Its for the kids when they visit.
Annoying that with the old BT Vision box i could have had it through ADSL (apparently) but not with YouView.
Guru
Message 20 of 20
Since BT started to do BT Sports over ADSL, they would only do this if Infinity wasn't available to you. If you could have Infinity then it was a no, no. That is whether you had a Vision or Youview Box.
I am very impressed with the Chromcast I bought though.
